Trans code issue
Old Oct 25, 2014 | 06:39 AM
BOTTLE ROCKET's Avatar
Default Trans code issue
I started getting the dreaded 1870 code (and the symptoms) It is activating the code when I am going up hill, usually with the cruise on. Should I bump up my TCC max slip rpm,( and if so, to what) or should I try to control it in the DTC chart?
It had started doing it before the swap, but I have just installed a new trans, and have a 3500 stall.
Thanks
