knock under load
Old May 25, 2004 | 10:31 PM
Appafella's Avatar
Smile knock under load
Well I finally woke up and purchased the enhanced atap. Ltrims are slightly negative and zero out at WOT. My problem is I get knock if I punch it at a low RPM, say 1500 in 3rd, like 5.5degrees. Also I get knock at about 4500 rpm at WOT, but not as severe, usually 2-3 degrees. I am just looking for a few pointers to get me rolling in the right direction.
Old May 26, 2004 | 06:47 PM
Appafella's Avatar
Also the o2's read B1 - .920-.930 and B2 - .940-.950 at WOT.
Old May 28, 2004 | 02:23 PM
dissonance's Avatar
what year car do you have?
do you have headers? other mods? maf ported? screen!?
give me some more details and i might beable to help.
Old May 29, 2004 | 01:02 AM
Appafella's Avatar
Lid, catch can, long tubes, dual exhaust w/ xpipe, 4.10's, I had milled my heads .30 after hydrolocking the motor a couple years ago (long story), vacuum ref.fuel pressure regulator, 38lb injectors and a fuel pump, EDIT. I use to have a turbo. (even longer story)
Jeremy
Old May 29, 2004 | 01:03 AM
Appafella's Avatar
Stock maf, and its a 1999 Trans Am
