0411 Pcm And 99 LS1 Harness
Old Nov 24, 2014 | 12:18 AM
impalasshoutx's Avatar
Default 0411 Pcm And 99 LS1 Harness
Will I have to change anything on my 99 fbody ls1 harness if i use a 0411 pcm from a 02 silverado 5.3? Only reason I am asking is cause I notice the pinouts dont match match between the two ive searched everwhere but havent found the right answer. My ls1 pcm crapped out and I have a 0411 lying around from a previous swap project that I want to use.
Old Nov 24, 2014 | 01:11 AM
MontecarloDrag's Avatar
Just flash it with your previous tune or a stock one for your car. It will work good
Old Nov 24, 2014 | 12:51 PM
Thanks for the info.
Old Nov 24, 2014 | 01:18 PM
codyvette's Avatar
Just to verify, you have to write entire which will include the 99 F body O.S. You will have to license the PCM and the O.S. unless either or both are already licensed.
