need help replacing ecm
Old Nov 25, 2014 | 09:36 AM
douniasg's Avatar
Default need help replacing ecm
I want to replace the ecm in my 1998 corvette with a backup ecm I have
from a 1997 corvette both are licensed through hptuners. I will flash the custom tune I have on my 98 ecm on to the 97 ecm but what about the vin? Does that need to be changed? I switched them out but there was no power at the ob2 port? Could it be because the vin # does not match? Thanks
Old Nov 29, 2014 | 11:13 AM
Pacer Racer's Avatar
Unless Corvettes are wired differently then most other GM's the power at the OBD2 connector comes from the same fuse as the cigarette lighter
Old Dec 1, 2014 | 01:39 PM
douniasg's Avatar
yeah I am trying to figure out why I get no reading at the ob2 port when I swap to the 97 ecm (could it be because the vin # does not match the car or the ecm is a dud?) car powers up fine with its original 98 ecm.
I can't believe I can't get an answer to this question not even on hptuners. I guess I have to throw more money at tuners
Old Dec 4, 2014 | 02:02 AM
tsench's Avatar
98 and 97 both wiring are completely difference harness
Old Dec 4, 2014 | 05:42 AM
codyvette's Avatar
I am not sure about the wiring differences but the O.S. and VIN change will not effect the physical outputs of an ECM. I am sure there are wiring diagrams available for free.
Old Dec 4, 2014 | 08:17 AM
douniasg's Avatar
ok did a google search the 98 fbody has a different harness but the 97-98 corvettes use the same harness and ecu so that's not the problem for me. If
the different vin # does not matter and the ecu should power the ob2 port then something must be wrong with the 97 ecu. I think I will try a refurb ecu (cardone) from autozone cost around $150
