Feedback on my tune?
One particular issue the car has is that it will rarely start with the AC on. It'll fire up and die in a couple seconds. I don't know if this is normal or not for cammed cars. Sometimes it'll manage to stay alive, but the RPM falls very very low down to 300-400ish and it kinda struggles there for a bit or it will surge really bad, but eventually jump starts itself back to life at normal idle RPM. Sometimes it even does it with the AC off, particularly the surging RPM. I know it's hard to give good feedback on this without seeing the car do it for yourself but if anything sticks out to you in the tune that might cause what I described please point it out.
Thank you.
Forgive my newbiness but is a scan log just a scan with vcm scanner or something else? If that'll help out then tell me how to do it and I'll post it up for you and anyone else who finds it useful.
However I don't get why something this simple was so difficult for the guy who "professionally" tuned my car. I took it back to him a couple times and he did some things but nothing changed it and he seemed lost... First time using HP Tuners and I almost got it figured out... Definitely know now not to go back to that guy. Curious how much power may be left on the table to be opened up with a better tuner...
I'm not sure if I'm looking at the correct one but my start up airflow delay table is at 4 across the whole temp range. Should I change it to 25?
Am I risking any issues here making these minor bumps in numbers? A/F ratio getting lean or anything of that sort? Don't want to do anything to drastic and damage something.
I also bumped up startup air flow just a tad a little while ago and noticed startup improvement with both A/C on and off, but still have RPM falls and surging with the A/C on.
Thanks a lot for the link to that guide. Will start looking over that next.
the next is adaptive airflow. these values add or subtract air from the base airflow value depending on what the car needs. in your tune the a/c max and min are both set to .5 g/sec which is stock. this means that when the ac kicks on the compressor might want 2 g/sec more air than with it off but your table only has room for .5. the base airflow vlue in your car may be high enough that thats ok but without a scan you cant tell. pop in these values, they will provide more of a cushion either way for a/c.
Also should my startup airflow numbers be similar to what's in that picture? Or is that a stock table or something? Because mine were already much higher than that before I messed with them.
I also started messing with vcm scanner a bit earlier so hopefully I can get some scans up soon. The weekend is coming to a close though so I won't have as much tuning time during the week
will definitely keep updating with every change I make though. and both those tables were taken directly from your tune. the lower one was called "startup airflow initial" and "startup airflow delay" you may have been looking at frictional airflow. they both add air in the same way just for different reasons. I chose to add to that because the frictional airflow value was already decently high. again that table is what your car is right now at least in the tune you sent first. add to that and see what happens. if the car starts, flares up then drops and dies try increasing the delay longer and slow the decay rate, that will make sure that it waits longer before it subtracts the startup airflow and that it takes out less every millisecond.
and yes if you high light all the cells and enter 1.25 in that top right box then click the + sign it will add 1.25 to all the cells. if you want to reduce the cells by 10% then you would simply highlight them again and enter .9 in the cell box and click the x. increase by 10% would be 1.10 x
I tried doing a cold idle scan and setting up the running air flow the way it says to in that guide. I added the Idle Desired Airflow PID to the table, however when I go to histograms there isn't an IDA histogram for me to copy over the running idle airflow table in VCM editor... I don't know how to make that histogram show up. I must be missing something?
the config is pretty easy, just download it and then open the config in the scanner everything you need should be there in the histogram. do the sca and then under teh desired airflow histogram just right click load all data and ensure its in g/sec
