blinking service engine light only while driving
to make matters more complicated can even be fuel related
did you remove all old fuel ,flush the tank,lines and injectors?
todays fuel does nasty things when sitting even 6 months
I have a wide band in the car and it reads normal when the light is blinking, 14.2, its in the green.
btw thanks for the replys a lot of helpful info from you guys thanks a lot.
If it sat for three years I would probably lean towards a dirty injector. What does that plug look like?
If it is an injector you could trying running Seafoam in the fuel or BG's KKK fuel treatment if you know someone that works at a shop with a BG guy.
If you do determine it is fuel I would either have an injector cleaning done on the car or take them off and have them cleaned/flowed.
