need timing help.
Old 01-20-2015, 08:57 PM
vissiajs's Avatar
Default need timing help.
I have an lq9 408 stroker, 317 heads worked a little, gmpp hot can. Sitting at 10.16-1 compression. I have a fast xim with fast ezefi multiport and trying to figure out what I should set my timing at. The base settings from fast are....
Idle 20°
Max timing 24°
All in rpm 2800
Rev limit 6000
This motor is in a 92 extended cab shortbox 1500 with a nv4500 4x4
Engine runs good, but have a feeling I might be leaving some power out there
Quick Reply: need timing help.
