PCM Problems HELP
Old Jan 31, 2015 | 06:13 PM
00keeganws6's Avatar
Default PCM Problems HELP
I have a 1999 blazer with 5.3 swap and when I unplug my pcm and plug it back in it does fine until I turn it off . When I try to start it back the security light comes on, the fuel gauge, the temp gauge, and gear selection indicator doesn't work but the engine starts and runs fine. I unplug the pcm then plug it back in everything works fine till I turn it off. I've tried two pcm's same results. When its working my obd scanner will connect to the pcm when its not it won't connect. Any ideas?
Old Jan 31, 2015 | 06:37 PM
MontecarloDrag's Avatar
You have a loose or shorted wire, it is making the Class-2 bus to fail. The OBD2 plug and the cluster are both hooked to that bus.
If you can't find the damaged wire you may want to run a new one directly from the PCM to the cluster and OBD2
