any wideband commander users out there?
trying to test one out and I can't get an accurate rpm signal.
sensitivity is set to high
divisor is one
using the white wire off the pcm, same one I use to drive my shiftlight.
what am I doing wrong? any tricks to make this work.
this is on a 98 if that matters
thanks!
divisor is one
thanks!
I have one. Below are my settings:
divisor is four
using the same wire you are BUT I have heard of several people having problems trying to use the WBC on the white wire with anything else, like a shiftlight.....
divisor is four
divisor is one
thanks!
divisor is one
thanks!
