Stop drilling those TBs, fix stalling without computer tuning...
TIA
I've been tinkering with the car some more. I just reinstalled the A/c into it, and that aggravated my crappy idling. Also even after the dyno tune it had some surging or bucking at low throttle or no throttle at lower Rpm's. I have been fighting the throttle body for weeks now. If I screw the throttle open far enough to bring the Iac counts down to a reasonable level, the tps reads 2-4% open even though there is no throttle.
I was reading the post; Stop Drilling those Throttlebodys
https://ls1tech.com/forums/showthread.php?t=177230
So To fix my problem I had to drill the Throttle body. I ended up with a 3/8" Hole in the blade. This brought the Iac steps down to a reasonable level, I show about 5-10 Iac steps at hot idle no a/c, and about 100 Iac steps with the A/c on. And WOW did that make a incredible difference in the driveability and stability of the car!! Day and night difference, It has no bucking or surging anymore!!!!
So with that big of a engine and cam, and a small throttle body it needs a hole. No amount of resetting the tps will fix it if the blade is open so far that the tps dose not go back to zero.
Also I did try to elongate the tps holes and that helped some but not enough.
__________________
My throttle body blade had a hole drilled in it when I got the car. I am also running the vacuum system that is stock on my 70 which has ten miles of vacuum hose and probably has a few leaks.
1) You will want to monitor your IAC, Idle Speed, throttle position voltage and your throttle position %.
2) With the key in the ON position, adjust your tb set screw until your throttle position is 2%.
3) Turn your key to the OFF position.
4) Unplug your Throttle Position Sensor (TPS).
5) Turn your key to the ON position for a few
seconds, and then OFF again.
6) Plug in the TPS and then turn your key to the ON position and restart logging. Your throttle position will now be reset to 0 degrees and about .45-.55 volts. Any higher can put you into the wrong fueling cell.
7) Start your engine, if you are not at your desired IAC position redo the above procedures in smaller increments.
If this does not get the voltage where it needs to be, where do I go next?
