Need help. Can't get to idle in drive
I'm having problems getting it to idle in gear. It idles just fine in P/N. Idle is set to 850rpm's. It idles fine in P/N but when I shift into drive it drops to about 450rpm's and wants to stall. Can someone please take a look and my tune and log and see if they spot something obvious thats wrong somewhere. I've been working on this forever now and spent hours and hours researching with no luck. I've played with the timing all over. I've drilled the TB and got my IAC's all the way down to 30 in hot idle(230*F) and nothing seems to work. In P/N idle my RAF table runs great about 8.3-8.6 but the in gear doesn't seem to like anything I put in there. I did get Reverse to catch idle if I put the in gear values in the RAF table all the way up to 15 but doesn't hold when put in Drive plus I don't feel this is right. That's almost double of the P/N table!
Here's the setup:
2000 Silverado 1500
6.0L LQ4
LS3 heads
Cam specs:
.610 .623 lift
223 239 duration @.050
LSA: 114
Whipple side mount supercharger
LS9 Injectors
Original 3 bolt TB drilled hole
Also if someone can confirm my injector data, offsets, and pulsewidths that would be great as there seems to be a lot of misinformation all over the place for the ls9 injectors.
If anyone can spot something obvious in the tune or give me some ideas to try as I've run out I'd greatly appreciate it!
If you want to send a PM with your email I will send you a tune file of my stroker when I was using LS9 injectors so you can compare. I also have spread sheet for the LS9 injectors I will send as well.
Is it normal for it to raise up in the 80-90kpa range when shifting to Drive or will it drop down once everything is right? Before Reverse would catch and hold, it would go to 80-90kpa and timing to negatives but now that that holds idle it goes to 64kpa and ~18* timing in Reverse now. Not always but sometimes. IAC's never seem to max in either direction either.
I would like to see a driving log. Speedo is working I'm assuming as well as TPS, maybe get commanded fuel in the table for a clue. I thought maybe OL idle was set in the PE tables but that would not explain the timing.
Your MAP maybe a result of timing & fuel changes in/out of gear.
Tuning basics 101 you have to be in good mechanical condition, you cannot tune around nor should you tune around problems.
nice!
