Need help!!! Wanting to run an ls1 with a newer e67 ecm
"The company also offers the TRG-002-R 24X to 58X Trigger Conversion Module (P/N L460125206), which allows earlier engines to be installed in newer cars." http://www.autoserviceprofessional.c...e-installation
Given what we thought was the small market for this product it was put on the back burner to make room for other product development projects.
Where are you located and what is your timing (when do you need one)?
Your fastest option is probably going to be to swap the crank reluctor and cam gear in the engine. Another option would be to change engine controls (change ECM and harness) but that is more complicated and likely costly.
Regards,
