Setting LS1 BS3 injector pulse angle
http://www.hptuners.com/forum/showth...ereencing-what
I would summarize it as having almost zero effect on WOT performance (because the injectors are running 80% of the time anyway) and having only a small effect on low to mid throttle performance. The suggestion was to adjust the Injector timing (open loop) for the highest VE table values in the idle and low throttle range.
Again, no idea if that is even what you are asking. Just trying to get the conversation started.
