lq4 p0300 help
Correct me if I am wrong, but when you disconnect the MAF, you are forcing open loop operation, the fuel trims are ignored (reset?) and fueling is running just off the VE table.
Since there is no 15% adjustment, I'm not surprised it lacked power.
Assuming the engine is stock, I would start by checking the fuel pressure which is supposed to be 58psi. I think that low pressure would give you those symptoms.
Note: I am unsure about my advice because I am unsure that disconnecting the MAF forces open-loop operation. Mostly I'm just trying to get the conversation going and hopefully an expert can confirm or correct me.
