Initial fuel pump prime table
Old Mar 14, 2015 | 10:37 PM
TDMKR496's Avatar
Default Initial fuel pump prime table
I need to adjust my initial fuel pump prime (if possible) on my 411 PCM, anyone know what table it is located in?? I tune in EFI Live but it should be the same table either way...
Old Mar 16, 2015 | 09:56 PM
LSX Power Tuning's Avatar
What OS number are you running?
Old Mar 17, 2015 | 05:35 PM
RonSSNova's Avatar
I remember reading in the HPT forum that the 2 sec prime is hard coded and can't be changed?
If it can, I'm all ears. I'd prefer to let my PCM control the fuel pump.
Old Mar 19, 2015 | 11:19 AM
jimmyblue's Avatar
Moderator
In the stock F-body tune I see a couple of things
under Fuel>General, Cranking Fuel section. There is
a Prime "button" which sets fuel pump run time at
10 sec at normal temps. But there is also a Fuel
Pressure Delay that is set to zero, meaning the
"prime" injector pulse can happen before fuel pressure
is built (say, in the case that you have a crappy check
valve, or some other scheme that lets the rails bleed
flat or even vapor-lock).
You ought to see whether you have a problem with
too short a pump pre-run, or if it's really "premature
ejaculation" (prime shot before full pressure). Check
the fuel rail pressure behavior across a cold start
and a hot start, and so on.
Old Mar 23, 2015 | 03:07 PM
Johnv's Avatar
Table B9104 in EFILive, got mine set at 10 sec.
Old Mar 24, 2015 | 09:20 AM
TDMKR496's Avatar
My rail pressure isn't always at full pressure is why I was wondering which table to modify. I will look at Table B9104 in EFILive and see what I can do. I believe my pump is only coming on for 3-4 seconds.
Old Mar 28, 2015 | 08:37 PM
TDMKR496's Avatar
I do not have table B9104 in my OS :-(
