I have joined the lambda gang! couple questions
So when I was tuning with afr I would aim for 10.9ish afr on meth.
Now that I log lambda should I should for the lambda equivalent of 10.9 or the lambda equivalent of say 11.5afr?
Is there anyway in hptuners to set the stoich in lambda? It's factory at 14.68xxx afr. If it can't be changed to lambda should I change it to e10 which is 14.1afr?
Thanks
Alex
Thanks
Alex
Thats what makes using lambda so awesome, it is always the same thing
Now second part is setting stoich in the factory pcm. Can you set it with hptuners to lambda? If not should it be set to 14.1 or so?
The other nice thing about tuning with lambda is that its very easy to tune with it because lambda at stoich is always 1 volt so that means that any portion of lambda is a percentage. If your target is .77 lambda and your logs are at .75 you can take out 2% fuel and be at your target.
Are you logging directly in lambda or are you converting to lambda from afr? You should be logging directly.
Is that what you mean?
