SES AFTER CAM INSTALL SOME Q's
I installed a comp cam, with the comp dual valve springs and a set of stock LS6 heads (have the longer valve stems) and Comps 7.4 hardened push rods.
The car has two problems at idle it shows missfires in ALL 8 cylinders and will set the ses light, it does clear up above 1300 rpm's the second thing is while driving like 5th or 6th gear i get a surge/miss every so often and it does show on the missfire graph but doesnt seem to be any one cylinder. I did do a search but none that i found mentioned all cylinders at idle only one or two? Any help is greatly appriciated.
