over fueling wont run
we are kinda stuck for ideas tuner said there might be problem with wirring thats why we changed pcm's over to check .
it doesnt seem like its wirring pcm engine or tune
would love for someone to point us in the right direction as we can not think of anything that could be causing this issue
cheers guys
rick
I suspect this mystery cannot be resolved without hooking up a tuner, such as HP Tuners or EFILive, to determine what is going on.
As a wild guess, the PCM that works on both engines might be set to (stock) closed-loop operation which lets the PCM auto-adjust to minor engine differences. The PCM that only works on one engine might be set to open-loop operation which has no auto-adjust.
You best solution is likely to send out the PCM to a tuner, giving them your car and engine specs.
