Vinci Handheld prgrammer
personally, i would use the vinci 047 or 062 cam before the comp 216/220. look up posts from marc w on the truck section. he used to have the comp 216/220. then he moved to the vinci 047 and had better results.
also, back when i tuned the wife's car when i put heads on, i had the borla exhaust. after i installed the bassani tru-duals, it richened the car back up. i had to back out the fuel i added there also. now that i have the vinci 062 cam in, i'm at cam #3.
what this shows you is you don't always need tuning to get maximum results.
-10% on timing. I have leaned it out -10% enrichment, may go to -15%. Will change again next month with the fast 90 and LG throttle body and post results.
What are some suggestions a/f and timing from you guy's that have had yours for a while.Thanks in advance.
heres a scenario for you
the engine is a 365 ci lsx with ported heads and 9:1 scr
single 76mm turbo with a/a intercooler/looking to about 7-15+psi
victor manifold with elbow, 60#injectors
going in a 95 camaro with a t56
i can use which ever year f-body pcm with the harness i have for stand-alone
its a custom unit that allows you to use 98-02 f-body pcm
which pcm year model do you recommend?
also looking to use the 02 ZO6 cam or something similar with a wide LSA
More street/strip car daily driver with manual boost controller
really the only thing holding me back is the inexperience with laptop tuners
and i want something that i have some type of control over and use as a learning device
i do not want/wont pay somone to tune this car
if i cant get the pcm issue figured out i will resort to carb.blow-thru
i can tune the the hell out of a double/pump or demon,but this would be a last resort
any info or advice suggestions?
do you think i can tune this engine with the vinci tuner?
thanx
sorry for the long post
Thanks
thanx
