Vinci Handheld prgrammer
· Before attempting to tune the vehicle, assure that the battery is fully charged. We have had several instances of the vehicle not accepting the tune. Discussions with the vehicle owner have caused us to suspect a partially discharged battery or poor battery terminal connections. This will cause the tuner to lock-up during the tuning procedure.. In most every case, once the battery was brought up to full charge, the onboard computer accepted the tune.
· If the tuner locks up during tuning, turn the key off and remove the tuner cable. Double check battery condition and assure that all electrical devices are turned off in the vehicle and all of the proper fuses have been removed. Turn the key on, install the tuner cable and try again.
What do they mean by remove all proper fuses???? Am I missing something here.
Man I'm trying everything to solve this.
The new battery has 850 cold cranking Amps. That is enough to crank a battleship.
I even applied dielectric grease to make sure that the connections are responding well.
I'm baffled and frustrated.
I would recommend not to use a TC higher than 3000 stall otherwise you'll have to tune via Edit or HP as this handheld doesn't adjust higher stall parameters needed to b changed (like trans abuse mode)
here's the link to the christmas sale page
http://vincihighperformance.com/2004...LE%20PAGE.HTML
Do you know the RPO for "traction control" option. I don't think I have it but if I had the RPO. I could check on my driver door but I don't know the option code for that either.
Sometimes under wheel spin I get an idiot light saying "Loss of traction" flashing on the guage screen.
99 pontiac formula
automatic
stock converter
3.23 gears
stock ls1 intake
stock ls1 cam
VHP airlid
VHP air filter
VHP MAF ends
VHP/Crane 1.89 accelerated lift rocker kit
VHP/Crane dual valve springs
bassani 1 5/8" optimum length headers w/hi-flow catted y-pipe
borla catback
VHP ported 4.8L heads
no cats
mr gasket .042" head gasket
as the notes say, i ended up using CAM #3 +10% power enrichment.
Question (car is a 99 C5)I know the Vinci site says to use a stock MAF.How would the SLP 85mm work with the Vinci,SLP says the MAF is recalibrated and should be used with a stock PCM tune.
I am going to order a MAF in a week,either a stock replacement from Corvette central,or the 85mm recalibrated SLP one.I will be using the Vinci programer for sure,so i want to get the right MAF.
Mahalo..........Todd.
I cant wait to get new times this year once the track opens. I think its time for some DRs though. Otherwise no traction out of the hole.
If i disable my A.I.R. codes with HP tunner,will they stay disabled after loading/tunning with the Vinci?I really don't want to hook the A.I.R. back up.
Mahalo....Todd.
Mahalo....Todd.
Mahalo....Todd.
