Long Term Fuel Trim = 0.0%, always
#61
thanks to coSPEED2, this problem is solved.
It was so strange having STFTs, no O2 codes and all wires from the O2s to the PCM testing fine that coSPEED2 suggested I take the car to a GM dealer and have them re-flash the computer back to the latest OS. That was it. I've got LTFTs again and can start tuning in earnest.
coSPEED2 has been beyond great in helping me with this issue and tuning in general. I'll buy my parts through them from now on...
Something like this:
1. set PE to 1.0 up till 1200RPM
2. set TPS enable PE to 0 up till 1200RPM
3. set open loop F/A to 1.0 up till idle MAP, so if idle at 60kPa, 0-60kPa from say, 20*C up
4. disable LTFTs (it sucks... a lot) (not necessary for this, but LTFT truly do suck)
5. set PE MAP enable to 15kpa
6. set PE enable delay RPM to 0
7. disable the P0131 and P0151 DTC codes
8. disable STFT open loop enable (if its not already)
Works for me.
Works for me.
Like it's been said though, there's more than one way to tune a car, and multiple ways seem to work just fine.
#62
Watch gen3 computers on any closed loop startup (or open loop for that matter if you have stfts on) and ill guarantee you youll see something happen at exactly 100 seconds of engine run time. Just let it sit and idle or drive it. Itll happen either way. I cannot tell you if it happens when you turn both off and use a wideband though.
I have never had ltft issues either. And I've tuned cars with some large overlap as well.
#63
#64
It seems that so many people like SD because there are other issues at hand. SD will mask them unlike MAF. Both ways will land you the same result as long as they are done right. There are some limitations to MAF, but most street cars won't max their MAF out, and I have yet to run into issues with reversion.
#67
I put a whole new ECU in the car and modified the stock flash instead of applying any existing flash file I have. A few days and like 6-8 runs later, I still have LTFTs so that's good. I also replaced my 60lb Dekas with 42lb Deatschwerks injectors. I think I have the right info in the tune for them.
With LTFTs to use with the STFTs, I'm now tweaking the VE table to try to get fuel trims where they should be. Any thoughts on the attached?
#69
BTW, I changed that 200% to 10% and my STFTs and LTFTs went to -100 across the board, so I re-set it to 200%... And looked at a stock tune for my car and it's 200% there
