Does the E38/LS3 Read Oil Pressure / Temp?
Old May 20, 2015 | 12:20 PM
Ericsworld's Avatar
Default Does the E38/LS3 Read Oil Pressure / Temp?
I'm trying to hook up a gauge that reads info from the OBDII port. I was wondering if the oil pressure and temperature will be built into the engine and PCM readout?
I know the coolant temperature and RPM should be there... not sure if I'll need to get a separate sender and hook it up to the gauge separately.
Old May 20, 2015 | 09:20 PM
aknovaman's Avatar
Oil pressure and water temp is yes.
Old May 20, 2015 | 11:33 PM
Ericsworld's Avatar
Cool... do you know where exactly the ECU's oil pressure sensor is located on the engine? And its coolant temp sensor for that matter?
Old May 21, 2015 | 06:17 AM
aknovaman's Avatar
Water is in driver cylinder head between the front two spark plugs. Oil is in top back of engine behind intake.
