HPT Pro and AEM Wideband
Old Jul 7, 2015 | 12:07 PM
RENE'S RAGE's Avatar
Default HPT Pro and AEM Wideband
I have the standard HPT with the AEM wideband wired through the erg. Can't seem to get it to read on screen.
Thinking about upgrading to the HPT Pro. Is this a plug n play for the Wideband?
I know it wires into the EIO terminals. Will I have to set the voltage offsets?
I have research this, but no luck.
Thanks
Old Jul 8, 2015 | 07:19 AM
mikesimpalass's Avatar
sub'd, I too thought that you could log wideband o2s with hp tuners standard, as long as you used 5v signal in the pcm, egr, ac, oil pressure, etc.
Old Jul 8, 2015 | 08:37 AM
LSX Power Tuning's Avatar
Thanks
You will still have to set voltage offsets even with the Pro. Even though its still the same process basically I think it works better logging the wideband with the pro vs egr or ac with the standard.
You can but you have to deal with ground offsets.
Old Jul 8, 2015 | 01:10 PM
watman02's Avatar
Can you elaborate on voltage offsets?
