-30 short term fuel trims need help
OP. Have you TUNED your car? If i read right, you added a bigger pump and have 42 lb injectors? your FP is too high at idle as well. More so if its vacuum referenced. Your o2's are both agreeing that there is 30 percent excess fuel. if you multiply stoich by .7 (.30 rich) you would get 14.7*.7= 10 afr pretty much. You are running pig rich and have probably fouled plugs and your oil. Your STFT get closer to 0 when you turn on your LTFT because that's the whole point of LTFTs. Get a tune if everything in your fuel system is mechanically good.
42# injectors are good for 512hp (@43#) plus you raised the pressure (which adds more).
You might be good for as much as 600hp (yep @ 64# with those injectors you are good for 615hp).
Not that you will make that much power, but the injectors are capable of supporting that much. (more if you max out duty cycle!)
Fuel pump wont affect your tune, except at the top if it falls short.
Regulator only affects the tune by changing the fuel pressure.
Therefore as and outside fuel being added (spraying with carb cleaner or something flammable) if there was a vacuum leak in both cases fuel trims would drop due to the o2's seeing less un consumed oxygen (richer afr).
