dyno vs street/strip ??
Old Jul 15, 2015 | 06:31 PM
stherngent's Avatar
Default dyno vs street/strip ??
Pros and cons any benefit between the two, any and all help greatly appreciated.
thanks
Old Jul 15, 2015 | 06:56 PM
HCI2000SS's Avatar
Depends on goals, budget, etc...Both is needed for the best results
Old Jul 15, 2015 | 06:58 PM
scotty2000ss's Avatar
Dyno to start. Data log at the track helps too.
Old Jul 15, 2015 | 07:17 PM
LSX Power Tuning's Avatar
I tune on the dyno (load bearing) and then go to the track and 99% of the time do a full pass straight from the dyno. The dyno saves a lot of passes and I can get data easier and faster without having to worry about the cars suspension working or blowing the tires off.
Old Jul 15, 2015 | 07:50 PM
stherngent's Avatar
Yes I'm wanting max effort/power
Old Jul 15, 2015 | 09:21 PM
redtan's Avatar
A street/strip tune can get just as much power as a dyno as you have a basis for comparison on what's working or not. Only downside is time as this can be accomplished much quicker on a dyno than at a track.
For purely power, hit the dyno and tune the **** out of it until you get the most power.
Old Jul 15, 2015 | 11:09 PM
joecar's Avatar
Dyno allows you to verify fueling and timing in a controlled environment/manner (helps to avoid engine failure).
Old Jul 18, 2015 | 12:41 AM
stherngent's Avatar
Ok, thanks guys!
