where to put fan temperatures?
You should test it in boiling water with a thermal probe and find out when it 1st begins to open and when it is fully open and then match that with fan on/off values in PCM.
I never buy such stats, your better off mod'ing a stock one with shims so you can control at what temps it does in fact fully open.
Of course if the engine makeup is causing it to run hotter no matter what the stat is the temps still will be hotter so your setup may require a better flowing radiator.
