Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tranmission Guides
- Camaro and Firebird: Why Can't I Shift Out of First?
Guide to diagnose trouble and recommended solutions
6l80 not shifting out of first gear
I have a Pontiac G8 setup with a 6l80 in a 67 Camaro. Psi harness. Got the car on the road and it will not shift out of first. I hooked my scanner up and the commanded gear is always 1. I am getting a rpm speed signal. I noticed the gear ratio is 8:00-1. I don't know if that is what it should be or not. I have not had any tuning done to the trans yet. I used my scanner to command the solenoids and they all changed state on the data stream. The brake switch is always showing applied even when the pedal is not pushed . I am getting voltage from the coverter lock up wires when they are not connected to the brake - 8v from one wire and 7 from the other wire - can't figure that one out.
Any suggestions. Thanks in advance
operating system) so the ECU and TCU (the TCU is internal and part of the valve body on 6l90 and 6l80's ) did not have the same VIN's. So long story short I had to find someone that could "marry" the ECU and TCU then had to remove the TCU and ship the ECU out with TCU. When I got them back and everything hooked back up everything worked like it should.
