evap code
Old Jul 30, 2015 | 09:24 AM
blackbyrd's Avatar
Default evap code
I hope this is the right place for this if not mods please move
I have a friend with a g8 throwing a evap code. I believe it is the canisters above the tank causing it i havnent pulled the code for him but I know dropping the tank was discussed to fix the issue at the shop he took it to.
the reason this post is here, his remote start doesnt work and he was told its linked to the check engine light (im not sure on this) and this is causing it to be disabled. He wanst to know if I can disable the code (i know I can) with hptuners and if that will allow his remote start to work again.
Old Jul 30, 2015 | 08:25 PM
2xLS1's Avatar
Yes SES disables remote start.
Old Jul 31, 2015 | 07:19 AM
blackbyrd's Avatar
so if I disable the code or associated codes and the light goes off he will be good as far as remote start goes
Thanks
Old Jul 31, 2015 | 07:56 AM
LSX Power Tuning's Avatar
Yes, if you disable the code with tuning software the remote start will work again.
Old Jul 31, 2015 | 08:27 AM
blackbyrd's Avatar
if only my other problems were that simple haha
thanks guys
Old Jul 31, 2015 | 11:59 AM
2xLS1's Avatar
Just clearing the code will get the remote stare working again until the code sets again.
