Will It Work? Can I fire it up on this tune?
Old Aug 27, 2015 | 01:13 PM
Darth_V8r's Avatar
Moderator
Originally Posted by tadams72
So this will either totally make sense or totally make me sound crazy. New bigger cam means valve events changed. Specifically, the intake is opening sooner. Should I be making an adjustment to have the injector fire earlier for proper evap of the fuel? Or is the existing tune good enough for idle to 2500 no load break in? Reading Greg Banish book Engine Management: Advanced Tuning which is what got me thinking about this. Thanks.
On the injector timing I've had good results delaying injector timing. Reduces the raw fuel out the tailpipe and greatly improves the smell.
Old Aug 28, 2015 | 02:54 AM
joecar's Avatar
Default Will It Work? Can I fire it up on this tune?
Originally Posted by mrvedit
You could post your tune here; tell us what model and size injectors you have.
Hi Ted/mrvedit,
EFILive's new tune file format has file type ".ctz"
would you please add this file tyoe to the forum attachment file types, thanks.
Old Aug 28, 2015 | 11:21 AM
tadams72's Avatar
Originally Posted by joecar
Hi Ted/mrvedit,
Good request. Thanks joecar.
Old Aug 28, 2015 | 12:34 PM
mrvedit's Avatar
Moderator
Hi Ted/mrvedit,
I have again(!) asked the Admins to add .ctz to the allowed file types.
Old Aug 28, 2015 | 04:14 PM
joecar's Avatar
I vaguely do remember that, wasn't that long ago...
Old Aug 28, 2015 | 04:15 PM
joecar's Avatar
In the meantime, post up a zipped up .ctz.
Old Aug 28, 2015 | 07:48 PM
ILuvPizzaTimes10's Avatar
On to the injector timing. I have 47* of positive overlap on my cam. I added 1 to the whole table. and it Greatly improved pretty much everything. smoother idle, cruise, fuel smell behind car. I did have to adjust the low rpm VE a bit though. As more of the fuel was "staying" in the cylinder now. Don't know if that helps. I think it really should be done at first rather then after its close to properly tuned.
Old Aug 28, 2015 | 08:46 PM
mrvedit's Avatar
Moderator
For comparison purposes, we don't talk about overlap at .005" as you have done. Please give us your overlap at .050" which is what we talk about here. For example, stock might be negative -12*, high performance around 5* and extreme performance around 20*.
But your comment is valid - the injector timing does affect the VE table, and therefore should be set, after some experimentation, before final tuning of the VE.
Old Aug 28, 2015 | 10:26 PM
tadams72's Avatar
You guys are taking me into deep water here so try not to drown me in the process.
So if I am tracking, what's important is to know the intake valve open at .050. In my case that is 7 BTDC on a 113+1 cam.
So knowing that, what table should I be looking at and what should I be looking for?
Old Aug 28, 2015 | 10:53 PM
mrvedit's Avatar
Moderator
We should not have starting talking about Injector timing in your thread.
I suspect the vast majority of people do not change it, regardless of their cam.
The stock values will be just fine for starting your engine and performing break-in.
Once you complete break-in and have your VE table tuned within 10%, then you might
consider experimenting with injector timing before the final VE tuning.
Old Aug 28, 2015 | 11:39 PM
tadams72's Avatar
It's cool. I brought it up initially but if it's beyond the scope of what I need to be concerned with on the base tune then I'll leave that be.
I am going to zip the tune this weekend and post if anyone is willing to take a look at it that would be great. Thanks.
Old Aug 28, 2015 | 11:56 PM
  #32
joecar's Avatar
You should be able to zip it by creating a Windows compressed/zip folder and copying the ctz file into it...
or you can use something like 7-zip (free) or WinRar or WinZip.
Old Aug 29, 2015 | 12:03 AM
  #33
2xLS1's Avatar
You can also just change the extension on the file to one that is allowed then change it back to the correct extension after you download it.
Old Aug 29, 2015 | 12:26 AM
  #34
eaglegoat's Avatar
You wont need to worry about it.
Old Aug 29, 2015 | 11:54 AM
  #35
tadams72's Avatar
Default Zipped Tune Attached
Ok guys, I've attached the zipped file so let me know if that works. Looking forward to some feedback on what I have so far. Again, the goal at a minimum is to be able to safely fire this thing up, run it to 2500 RPM at no load for about 20-25 minutes for a break in. Just want to get rings to seat, check for leaks, get a good heat cycle so I can re-torque heads, headers, etc. Then it needs to run good enough to load on a trailer to head for final tune.
Details on the build can be found here:
https://ls1tech.com/forums/generatio...all-motor.html
So let me have it. Thanks!
File Type: zip
Old Aug 30, 2015 | 09:49 AM
  #36
Darth_V8r's Avatar
Moderator
Just throwing this out there. If your start up tune dumps fuel, make sure you change your oil after the tune.
On mine the oil pressure dropped off, and when I drained the oil it smelled like gas. Fresh oil, and pressure back to 45 at idle.
I knew it was dumping gas, so no surprise but wanted to save you a panic attack
Old Aug 30, 2015 | 10:04 AM
  #37
tadams72's Avatar
Good info. I will keep an eye and a nose out for that. How rich were you running?
Old Aug 30, 2015 | 10:24 AM
  #38
Darth_V8r's Avatar
Moderator
Pretty f-ing rich. I got 10-12 mpg on that first tank. After NicD dialed it in I'm getting 19.
Just write it off as break in oil.
Old Aug 30, 2015 | 04:17 PM
  #39
joecar's Avatar
Ok, this is his IFR table (if he has the factory returnless 400kPa/58psi system then: vacuum is roughly above 408 and boost is roughly below 408kPa):
Code:
LABELS	Injector Flow Base (Grams/Second)
Delta MAP kPa	Value
128	5.133056
148	5.520019
168	5.881103
188	6.220947
208	6.543945
228	6.851074
248	7.145019
268	7.427978
288	7.699950
308	7.962890
328	8.217040
348	8.464110
368	8.704101
388	8.937011
408	9.165038
428	9.386962
448	9.604003
468	9.815917
488	10.022948
508	10.226073
528	10.426024
548	10.621093
568	10.813964
588	11.001952
608	11.187987
628	11.370116
648	11.550048
658	11.727050
688	11.901122
708	12.072997
728	12.241942
748	12.408934
768	12.573973
Old Aug 30, 2015 | 11:04 PM
  #40
tadams72's Avatar
Yep, factory fuel system. Only this different is bigger injectors and installed a ZL-1 fuel pump to provide more volume though still at 58 psi returnless. This is an all motor car also. No boost or spray.
Code:
Delta MAP kPa	Value
128	5.133056
148	5.520019
168	5.881103
188	6.220947
208	6.543945
228	6.851074
248	7.145019
268	7.427978
288	7.699950
308	7.962890
328	8.217040
348	8.464110
368	8.704101
388	8.937011
408	9.165038
428	9.386962
448	9.604003
468	9.815917
488	10.022948
508	10.226073
528	10.426024
548	10.621093
568	10.813964
588	11.001952
608	11.187987
628	11.370116
648	11.550048
658	11.727050
688	11.901122
708	12.072997
728	12.241942
748	12.408934
768	12.573973
