Will It Work? Can I fire it up on this tune?
The original tune was done by Vengeance Racing for a stock displacement and compression LS3 with Vararam Intake, 227/239 .612/.612 112+4 cam, ARH 1 7/8 headers, TR6060, Lingenfelter 9.5" diff with 4.10s.
New engine is LS3 based ERL 427, 11.5:1, Vararam Intake, ported LS3 TB, Ported FAST 102, Bosch 60lb injectors, ported TFS 255 heads, bigger cam (high 230's intake and high 240s exhaust, .620s lift and 113 +1), ARH 1 7/8 headers with no cats. I took the tune from Vengeance and adjusted the IFR, Injector Voltage Correction, Default Pulse Width, Injector Short Pulse, Small Pulse Adder, and Injector Offset. These adjustments were made using date provided by Fuel Injector Connection for their injectors. All this was done on EFI Live. I am by no means a tuning guru but trying to learn. Final tune will be done by a professional. I have dual widebands so I can monitor AFR to make sure I don't get dangerously lean or rich during the break in. I do not plan to run SD tune.
So any help from the knowledgeable ones is much appreciated. Thanks again.
UPDATE: So looks like I can't add a ctz file so I guess the big question is will modifying the injector tables for the larger injectors be enough or are there other tables that will need to be changed just to fire it up and runn at low throttle for the break-in. Thanks.
Without adjusting that up, you will be extremely lean. (A MAF might account for that, but MAF output has to agree within reason with other calculated values.)
The injector values are critical, but sounds like you have that covered.
Also, keep your HPT scanner running as you start it up to monitor everything.
It will also let you override the commanded AFR to force the wideband AFR into a safe range.
Idle is set to 1000 when cold and 950 warm.
All the injector data was set in accordance with and using data from Fuel Injector Connection.
Also, I am using EFI Live.
Seems things I need to be concerned with include washing the cylinders which I have taken care of.
Increased idle speed. Done.
What I am concerned with still is adjusting for the ported TB and ported FAST intake. Essentially keeping the motor from running away from me.
Anything else I should be looking at?
Thanks again for dealing with the noob tuner. Pushrods showed up tonight so might be starting the shoe horn back in place this weekend.
The injectors are FIC 631cc 60lb 3 bar long body.
All the things you speak of can be adjusted via EFI Live and yes they have the ability to do it in real time using RoadRunner VCM but I do not have that so ECM needs to be programmed correctly, or at least close, the first time.
All I am trying to do is get it close enough to fire it up, do the 20 minute up to temp break-in of the motor, then load it on a trailer to take it for professional tuning. My concerns are running too lean/rich, excessive knock, extremely poor idle, etc. Love the power and drivability that comes from EFI but in this case, I miss just being able to change metering rods, jets, and twist the distributor a little for timing. That being said, I do want to learn to do this effectively. Been reading and tinkering as I learn best that way. Thanks for the feedback thus far.
Ok, I figure this would give a decent representation of what has been changed thus far. This screenshot shows what has been changed from the stock 2011 LS3 tune to now. Open for opinions and I can screenshot individual table of the new tune as well. Thanks.
