new tune now p0332
would the new tune have anything to do with the knock code seeing the mail tune consists of 'improved knock handling" and "new spark/timing maps"?
any help would be appreciated
thanks
mike
is there a way to test a knock sensor?
i think the ecu retards the timing once knock is sensed.
i wonder if i clear the code, if i can check the timing and tap the engine and see if it moves??
now, is 0.04-5 a good reading? or should it be a full 5.0 volts?
the problem only started after driving it about 40ish miles. not the couple dozen times pulling it in and out of the garage and driving a few hundred feet down the street.
i would think if the ecu was bad it would instantly throw a code as soon as i started the engine.
