Atomic EFI Experts Needed - Sensor Help!
Old Sep 2, 2015 | 09:46 AM
john.tempest's Avatar
Default Atomic EFI Experts Needed - Sensor Help!
Hey Guys,
So I am in the process of actually assembling my motor and ordering sensors to finish the build, but I have hit a bit of a snag.
I have a LS 408 with a Scat stroker crank with a 58x wheel. The motor I stroked is a LQ4.
My question is this - Will the Atomic be able to run the 58x wheel if I install a newer grey 58x sensor above the starter and a new camshaft positioning sensor in the stock location behind the intake, or do I need to get a 24x crank? I know the LS2s the cam and crank is all on the front of the motor, but with the LQ4 this is not true.
I have an atomic EFI master kit 2957.
Top end is LS3
Wondering if anybody has any experience with this.
Thanks!
Old Sep 9, 2015 | 04:18 AM
Exidous's Avatar
Maybe you can use the Lingenfelter box just for the crank signal but I doubt the efi will accept an x58/x1 combo.
Old Sep 9, 2015 | 02:45 PM
Jason Haines @ LPE's Avatar
LS1Tech Sponsor
Default Trg-002
You have to have both a 58x and a 4x input to the TRG-002. It won't work with just the 58x signal.
