been play with HPtuner
Old Sep 19, 2015 | 06:29 PM
  #41
lilrobo's Avatar
what be the chances i have the wrong sensors installed ?? here is a pic like i said the moroe is a 06 silverado and the pcm is for a 01 or 02 camero ,, and the wiring harness is for the motor i believe ,, ( red & blue ) plug on PCM
Old Sep 20, 2015 | 12:24 PM
  #42
lilrobo's Avatar
i do have 13 volts on the pink and black wires
pass and drivers match up
pink ad black goes to whites wires
tan to gray
prup to black
still dont know what sensor i have ,i will check to see if there is a number on them look to be 2 it could be
12212156
http://www.oreillyauto.com/site/c/de...2205&ppt=C2181
Old Sep 20, 2015 | 07:31 PM
  #43
lilrobo's Avatar
well back to square 1 took apart my sensor plugs matched them up how i thought i they was supposed to be ,
i think they should go
blk =sig pos+ to pink
gray = earth to ground blk
wht =heater to tan 1 side and tan/wht other side
wht= heater to ppl 1 side and ppl / wht other side
still no good got this
either i still have bad wiring ot my sensors are bad
Old Sep 21, 2015 | 07:31 PM
  #44
lilrobo's Avatar
well i took 1 of mine out and check the heater wires ( white ) and the have about 7 ohms ,, i checked the other 2 wires ( tan & blk ) with a torch and heated them up and got nothing ,, so i might just have 2 bad sensors they was new when i installed them in nov , i have about 1700 miles on them
i am going to by 1 tomm and try it and rescan the car and see maybe that's all is wrong
Old Sep 22, 2015 | 08:32 AM
  #45
lilrobo's Avatar
i tested mine , and the heater is ok .but when i put heat to it nothing ,, so i am returning mine for new ones ,, hope that is it
thanks
Old Sep 24, 2015 | 07:44 AM
  #46
lilrobo's Avatar
got my new ones installed and still the same thing , no activity on both
i check the voltage i got 13v at the plug ( pink & black ) , i check the sensor at a idle i had .8 coming back from sensor ( tan and purple ) they show working ,, i am going to double check my wiring is good from the plug to EMc plug , could there be something else ?? all i did is go in and turn on the DCT's here is my tune maybe i need to do more
thanks guys
Old Sep 25, 2015 | 02:26 AM
  #47
joecar's Avatar
Default been play with HPtuner
Is your PCM pinned for 3-wire or 4-wire NBO2...?
Old Sep 25, 2015 | 01:54 PM
  #48
lilrobo's Avatar
4 wire
right now i have installed new sensors , and yes i have 13v at the sensors and i have .8 coming from the sensors , the issue i am having is i went in my hp tuners and enable them but i need to set the parameter within the tune , after it warms up i see no activity on both , by me just enable the codes that wont turn closed loop on ?
i need to learn how to set the parameters within the tuner
thanks
Old Sep 25, 2015 | 02:40 PM
  #49
LSX Power Tuning's Avatar
I just modified the tune you posted on the first page, this tune has the front O2 sensors turned on and it should go into CL and use STFT. If you made changes to the tune since you posted it just do a compare to the tune I attached and you can see what I changed for CL and for your front O2's to work.
File Type: hpt
Old Sep 26, 2015 | 07:04 AM
  #50
lilrobo's Avatar
thanks will do thanks a bunch
Old Sep 26, 2015 | 08:40 AM
  #51
lilrobo's Avatar
when i do a compare the stuff in red is the different things ?? whats does the green mean ??
thanks again
Old Sep 26, 2015 | 12:37 PM
  #52
lilrobo's Avatar
after about 5 min of idle i get this
Old Sep 27, 2015 | 06:58 AM
  #53
lilrobo's Avatar
does this mean they are not working ???
Old Sep 27, 2015 | 08:34 AM
  #54
They are not working.
Old Sep 27, 2015 | 09:14 AM
  #55
lilrobo's Avatar
I left it alone and drove to church and engine light came on, , what should i do, , double check my wiring? and connections?
Old Sep 27, 2015 | 01:18 PM
  #56
lilrobo's Avatar
could it be that i have my high and lows wrong ? i know the tab and tan/wht are low but what color do they got to ?
i know the 2 whit wires are for pink and blk
but the other 2 on o2 sensor does it matter ??
Old Sep 27, 2015 | 03:03 PM
  #57
lilrobo's Avatar
still not working , this what i have let me know if they are wrong the sensors do have a ground in the plug
Old Sep 28, 2015 | 03:03 PM
  #58
lilrobo's Avatar
mine says 01 camero and the plugs are red and blue on the ecm ,, does someone have a wiring diagram? i have look and several , maybe i am looking at the wrong ones,,, also my o2 plugs has 4 wires black,,pink ,, tan ,, purple , does that mean they are isolated ground ??
Edit/Delete Message
Old Sep 29, 2015 | 10:39 AM
  #59
joecar's Avatar
This is from 2001 F-car...
Old Sep 29, 2015 | 04:00 PM
  #60
lilrobo's Avatar
yeah thats the same one i have been using ,, i did just find this ,, i have bosch 15150 now says its a narrow band and 550mm long , i looked up one for a 01 camaro and its a 13029 same narrow band but 375mm long could that be it ????
