Stock convertor settings
Old Sep 10, 2015 | 10:53 AM
RockinWs6's Avatar
Default Stock convertor settings
Can some one please tell me for a 01 TA stock tune If the T convertor settings keep it locked all the times above 43 mph. Once the car gets into 4th gear above 43 mph no matter how far I push the pedal down it ill not unlock. It will downshift into 3rd and lock back up, but it won't unlock just the convertor if you come to a hard hill etc or are cruising up the highway and come to a hard grade. Thanks
Old Sep 10, 2015 | 05:08 PM
2xLS1's Avatar
Look at the mph #s in the 4th release row. You have to be below that mph at that throttle position for it to unlock.
Old Sep 10, 2015 | 05:32 PM
RockinWs6's Avatar
Thanks but I think the PCM has a aftermarket convertor tune in it. PWM isn't working, it locks hard and stays locked unless you go 100% in 4th. I don't have tuning software to look at it. I just wanted to know what stock was.
Old Sep 10, 2015 | 05:42 PM
2xLS1's Avatar
This is a stock table for a car with 3.32 gears.
Old Sep 10, 2015 | 05:51 PM
RockinWs6's Avatar
So it looks like it should stay loccked in 4th above 39mph at all times except above 81.25 %tps?
