Shooting Ducks! LS1 misfire
243's prc stage 2.5 cnc port milled to boost compression ~11:1
224r cam
LS6 intake
36 lb injectors
ls7 lifters
headers egr delete rear o2 delete
4.10's
all supporting mods blah blah blah
I installed NGK tr5 plugs that i just re-gaped .050. The car idols fine its a little hesitant on throttle response and when i go to take off it misses bad! stumbling all over the place it seems to clear up by 3rd-4th gear but when i try to roll into the throttle it stumbles all over itself again. I'm planning in checking fuel pressure since i'm still running the lt1 fuel pump which i'm sure is on borrowed time. It is throwing a code which i'm going to have read this week. I was just wondering if anyone has any other advice on were to look. I know a lot of things may cause this problem so i'm open to any advice you guys got. Should i move to a cooler plug with the bump in compression? different gap? i sprayed cab cleaner on intake and throttle body to check for vacuum leak and didn't get anything. Any help is appreciated
