HPTuners Tuning.....
My question is........Is HPTuners or even EFI Live this way? Or do I have to make a change to the table...upload that change, fire the car..and see what it did? Thanks guys.
I am a novice at this...so I may not be down with lingo quite yet.
Mine is a 2002 lq4, and it works.
Here's a quick video of how it work...
The RoadRunner is attached by USB cable. You can make changes while the engine is running, not running, keyoff or key on. Also, the roadrunner uses the active datalog to make changes you program automatically or you can make direct changes yourself.
For example, you can use the wideband sensors to feedback through the datalog and adjust the VE table as you drive. Makes cam changes a breeze. Something I did with it that was pretty cool, were spark changes.
I had some knock in one of my old motors. I setup the log to monitor knock, then when found, I set the RoadRunner up to reduce 0.5 deg spark per knock until there was no knock.
Go to EFIlive.com. If you have any Q's, feel free to pm.
