Running issues.
Old Oct 8, 2015 | 02:20 PM
zeusrotty's Avatar
Default Running issues.
Hey guys I have a quick scenario for you. I got the motor in the car and went to start. It won't start unless it's been sitting and then just dies. If I restart it it will not start unless I give it a lot of throttle.
I'm getting a lean bank one when I scan it but no actual code. Cylinder 1 header is warm, 3 is hot 5 is hot and 7 is hot.
O2 sensors are brand new. Pic shows show plugs 1,3,5 bottom is 1
1 looks like it's not even firing or very lean
3 is blackened
5 is wet and fairly clean other than a little blackness
Old Oct 8, 2015 | 04:15 PM
Old Geezer's Avatar
Post the tune and the scan log[s]...
Some serious lean going on.
Have you verified all the wiring is correct? Inj harness, coil wiring, etc.
Fuel psi is?
Some description of the set up is necessary to help...
This isn't you Yugo, I take it.. Too many cyls!
Old Oct 8, 2015 | 05:41 PM
zeusrotty's Avatar
Fuel psi is?
It's a swap car. 1987 Porsche 944. I don't have access to scan tool that will send codes or scans.
Old Oct 12, 2015 | 03:59 PM
zeusrotty's Avatar
Fuel psi is?
I have a little more info. The car now starts. It was a stuck lifter. The problem with the lean left bank still exists though. I have a little more info though. I was able to print out the information sheet from the scan. I am attaching it here. The back story with this is that I had an ls3 in the car before, but that motor blew up. Completely disintegrated a piston. Could it be that I got a bad tune on the original motor and now I'm seeing the results? Or is it possible that since I added more cubes and bigger air the left side is just lean because of it?
Old Oct 12, 2015 | 04:54 PM
mrvedit's Avatar
Moderator
Keep in mind that a misfiring cylinder will cause that bank to go very lean as there will be a lot of unused oxygen which is detected by the O2 sensor as very lean.
Old Oct 12, 2015 | 05:34 PM
zeusrotty's Avatar
Okay, but we did fix the cylinder, and it runs well. But we still have the lean issue. So could it be a bad plug or two? There is also a huge difference in temps from one side to the other.
Old Oct 12, 2015 | 06:03 PM
mrvedit's Avatar
Moderator
I would start with brand new TR55 non-platinum plugs.
Then if one or more plugs still look very different after running a while, I would swap the location of injectors to determine if one or more injectors are bad. Also a right-left swap of the coil packs might be helpful.
If that doesn't solve it, as Old_Geezer suggested, it might be time to verify the wiring,
even performing a continuity test from each injector back to the PCM.
Have you performed a compression and/or leak down test to ensure the engine is mechanically sound?
Old Oct 12, 2015 | 06:08 PM
zeusrotty's Avatar
Okay, I know the wiring is good. The plugs I have pictured are the same plugs that were in it before. So at least one of them is pretty fouled. I'll start there. What about the maf? We did leak downs and it's all good there.
Old Oct 12, 2015 | 06:50 PM
mrvedit's Avatar
Moderator
If there was a MAF problem all cylinders would be lean or rich, not a few here and there.
Old Oct 13, 2015 | 09:36 PM
zeusrotty's Avatar
Okay, so I changed out the spark plugs on bank one and fixed the stuck lifter. Now I'm getting a p0134 code. What does that mean? Did I dump so much fuel that I burned out the 02 sensor? Also, if my computer is for a 2002 camaro, should I be running AFS 75 02 sensors or AFS 105 sensors?
