Poor Running, Lean Bank 2
You're alluding to ECM being faulty, do you have a spare one to try...?
when it fails to refire does scantool read RPM while cranking, and do you still get spark/spray everywhere...?
And is rail pressure still within spec...?
How about battery voltage wrt to chassis ground and wrt engine ground...?
Does scantool indicate VAT enabling (one of the STATEnn pids)...?
I do not have a spare ECM. This one worked fine on the last motor and I have not had an error in flashing it but I suggested it because others have had the problem.
I'll double check RPM being read but I am almost certain it is reading during cranking.
Rail pressure is in spec from the moment the key is turned to on to after the engine dies. Not a rail pressure issue that I can tell. I might hook a gauge to the rail if I can get at the fitting (I flipped the rail to clean up the engine bay).
I'll have to get readings at the ground points though they are all perfectly clean and tight.
Not familiar with "VAT enabling (one of the STATEnn pids)." I'll research that a bit.
Thanks Joe!
when it fails to start, check one of the STATEnn pids (? I think STATE05) to see if the pCM is indicating that VATS has kicked in, which if it did it would prevent starting)(also, I'm not 100% sure how this has been implemented on the 5th Gen Camaro).
I have not logged VAT. The "state **" PIDs all say unsupported.
Next step is compression test all cylinders. I'll post the results tomorrow if I get it done by then. Thanks.
Travis
New lifters are in route as is a PurePower Stainless Steel reusable filter. A lot of folks will say that is a waste of money and it very well could be. Here's why I decided to go this route.
-I've got a buddy who runs them on a road track and swears by them. In the military we use them in a lot areas were filtration performance is a concern.
-Nominal Rating
