P0123 TPS Code
So I went back to stock, and I can't get the car to idle anymore. It reads 2% no matter what I set the voltage to (.63V was were it was set when I put it together - and I've set it from .61 to .67) and it idles really low - like 650RPM even though it's set for 900. I figure it wasn't getting enough airflow. But it's also throwing code 123 with the stock GM sensor.
What's the issue? Is it wiring? Is there something in the tune I need to adjust because it's reading 2% at an acceptable voltage? Is it the TPS sensor?
Car is pretty undrivable. The whole issue popped up in August and I've more or less parked it as I've traveled for work. But now I wanted to get it back on the road and this is pissing me off. It was high idling then so I bought the new TPS sensors and played with the TB, not knowing if the NW was actually moving of me or if the TPS was going out. But the new ones won't read low enough...
I do the TPS relearn each time I make an adjustment or swap TPS.
holes to allow more rotation toward a lower voltage
output?
Might check your 5V (and TPS-local ground) voltages
against a PCM ground at the PCM connectors, on the
off chance this is some sort of wiring or bent-reference
type deal?
Which is a TPS.
Jimmy, I have thought about that but didn't have that problem with stock. Closed it read around .4V. What would change now?
error seems roughly consistent with your problem (ought
to see 0.6V at rest, add 20% and you're over the fault
threshold).
Voltage regulators do fail. Some also do poorly at sinking
current and there could be some other actor pushing
the 5V reference upward through some attached
component. Might do a little debug, like snip the wire
near the PCM connector and remeasure - if it's back
in range then the problem is outside the PCM, if it
stays at 5.9V then call the PCM bad. Don't know
whether the 5V references are from easily reworkable
components or not, but could be this is salvageable
(individual regulator ICs are usually cheap and not
hard to R&R).
TPS separately, like use a 7805 regulator from IGN to
power it. And maybe whatever else is hanging off that
5V feed (like, if MAP sensor was 20% off that would
be a tuning mess too).
