P1515 trouble
Old Oct 28, 2015 | 08:41 PM
67stepside's Avatar
Default P1515 trouble
I'm not sure what to do next. I have a lq4 swapped into my 67 Chevy truck. The motor is a 6.0 from a Yukon Denali. I've checked the yello wire at the throttle actuator but looks good. TAC module had a hole in it from before I got it so I found another with same part number on eBay. I changed the throttle position sensor early last summer because it wouldn't shift out of first at WOT. Ran great until a couple weeks ago. Should I replace the throttle or change the actuator motor? I did this swap 3 years ago without any trouble. Thanks for any help.
Old Oct 29, 2015 | 04:25 PM
67stepside's Avatar
I removed the throttle body and will clean it tonight then reassemble. I'm going to replace the pedal sensor. I'll let you know how it comes out.
Old Oct 30, 2015 | 07:33 AM
gagliano7's Avatar
You should try checking in the conversion section since a lot people over there do the same swap and my have run into your problem.
