2014 l83 wiring
Old Nov 3, 2015 | 04:36 PM
frige's Avatar
Default 2014 l83 wiring
I posted this in the g 5 thread but did not get a answer. I need to cut down the factory harness on my l83. It is going in to a 89 c1500 and I have the harness as well as the computer. Does anyone have a diagram to help me out? There are a couple of guys that say they will supply me with a new harness but at 2000 bucks I cant afford that.
Any help?
Old Nov 4, 2015 | 07:37 PM
frige's Avatar
Crickets....
chirp...chirp
Old Nov 4, 2015 | 08:04 PM
76larkman's Avatar
check with Lt1Swap.com. Brendan has lots of info there.
Old Nov 11, 2015 | 08:32 PM
LLLosingit's Avatar
I'm not sure how good you are at wiring but why can't you plug the harness into everything you need to make it run then split the loom and remove what you don't have hooked up. It's not as simple as it sounds because you'll have some grounds and positive leads to figure out but it is possible. As 76larkman suggested try LT1swap.com I have used that many times.
