Any way to get ls2 ecu to work on ls1?
The pcm can run a damm lawnmower you just have to make sure the correct sensors are installed on the engine and it has the correct programming for your platform.
2006-2005 gtos used a 24X crank
Call speartech they can give you all the details and prices the above will just get you going in the right direction.
