Clarification on what Power Balance test values correlate with
Old Dec 8, 2015 | 02:24 AM
slpfirehawk415's Avatar
Default Clarification on what Power Balance test values correlate with
After reading some threads they seem to die without the answers I want. We know the HP Tuners power balance test shuts each injector off for 2 seconds and reads the RPM drop, but what exactly is the RPM percentage calculating? It obviously does not add up to 100% and thus isn't a relationship to direct RPM, so what's up with these values?
For example a 4 cyl engine may read 101%, 105%, 99%, 101%
We know its an imprecise test and shows a problem with only large differences, but curious minds need to know!
Old Dec 8, 2015 | 03:34 AM
Exidous's Avatar
It's used to test the strength of each cylinder. If there is no drop when one is shut off that cylinder is not firing. If there is a small drop the cylinder is weak. If there is a big drop the cylinder is fine. Obviously this is very general. The HPTuners just adds values to how much of a drop there was. You should be looking for large differences just like a leak down or compression test. Take their precision with a grain of salt.
Old Dec 8, 2015 | 02:42 PM
Ok I figured it out! Before the test begins cutting cylinders it takes a sample RPM. The percentages all relate back to the sample rpm. So if you sample 1,000rpm and the test cuts a cylinder and the rpm comes back at 1,050 it will show 105%. Seemed odd that you could cut a cyl and have it go UP, but I think it may relate to getting an insufficient beginning sample.
Glad this is figured out, people were talking about all kinds of crazy stuff in other threads lol
