Pick help
Old Jan 8, 2016 | 07:54 PM
ROCKETWS6's Avatar
Default Pick help
I have a gm performance 6.2ls3 and I'm trying to run a 5.3 Pcm from a 08 Impala. Car runs like poop with cam sensor plugged in. If I disconect the sensor it runs ok. Sounds like it's out of time all plugged in. I have different Pcm that still has vats installed and it runs good for a sec or two then shuts down because of the varts. Does the gmpp 6.2 have vvt or something?
Old Jan 9, 2016 | 12:27 PM
joecar's Avatar
Is the cam sensor subharness wired backwards.
