anyone have gmpp 376/525 base map
Old Jan 17, 2016 | 04:27 AM
Mitch-12's Avatar
Default anyone have gmpp 376/525 base map
putting an ASA cam in my ls3 in my hilux in australia and it would be really easy if someone has the file? i have HP tuners and efi live but a hptuners file would be best
Old Jan 17, 2016 | 07:27 AM
Gadgedizzle's Avatar
Use you stock LS3 map. set base, high and low octane ignition map from 400-1200 rpm 20* up to .36g/cyl
800-1200 rpm in ve map multiply by .8
copy 800 rpm and paste in 400 rpm and multiply by .9
copy 400-1200 cells (Remember to pick only the corresponding map values) from ve map and paste into cranking ve map. smooth to match.
That should get you good enough to start and begin tuning.
Old Jan 17, 2016 | 08:18 AM
joyridin''s Avatar
I thought I saw one on the HPTuners repository? I think I even copied it.
Old Jan 17, 2016 | 02:49 PM
Mitch-12's Avatar
Thanks I'll have to get an ls3 base map then. I have e67 ecu and at the moment it's mafless and turbo
Mitch-12's Avatar
Lol, maybe I should look 😂
