Low vacuum an issue with 0411 ecu?
Hey fellows, I am curious as to the capabilities of a 0411 ecu.
Is it capable of handling the low speed running characteristics of a 349"
big bore, short stroke engine with LS3 heads?
My concern is the lack of vacuum at low engine speeds when running this cam.
Will this ecu play nice with low vacuum at idle? Do I need to go to a after market ECU?
Bore is 4.125", stroke is 3.27"
CM LLSR
Grind number is LL230/350-LL236/340-111+3
230/236 duration at .050".
Lift is .595"/ .578".
Lobe separation 111 and 108 intake lobe center line.
Thanks for any thoughts.
John
CM LLSR
John
