Harness conversion ?
Old Feb 20, 2016 | 06:00 PM
welldonecj7's Avatar
Default Harness conversion ?
I am working on making a 02 Silverado harness stand alone and will be deleting my 2 set of o2 sensors. I am curious if it will be best to keep the original o2 sensors or repin the second set of sensors into the first bank sensor pins?
Old Feb 21, 2016 | 09:18 AM
Pacer Racer's Avatar
If you're running manifolds I keep the stock set up but if you're running long tube I'd switch them. If you're running shorties, it would depend on where the bungs are located.
Old Feb 23, 2016 | 12:11 AM
Alright thanks for the post, as far as the two types of o2 sensors is one better than the other?
Old Feb 23, 2016 | 12:27 AM
2xLS1's Avatar
The sensors are all the same. Some have different wire lengths and/or connectors.
Old Feb 24, 2016 | 01:46 AM
Alright I just noticed two different style plugs, thanks
Old Mar 6, 2016 | 06:23 PM
68shortfleet's Avatar
I delt with this recently on my conversion and wish I had repinned the rear O2's and got rid of the short wires.
Does anybody know which sensor part number has the longest wire on it? I could certainly take advantage of the extra lenghth. Needs to have a connector that fits a 98 camaro harness, I suppose it wouldn't be a big deal to change the connector out.
