Replaced Knock Sensors, now getting 2 codes.
My 2000 Suburban with the 6.0 LQ4 (200k) is giving me two knock sensor codes for bank one and two. I recently replaced the knock sensors after getting the code P0332. My rear sensor was corroded like a lot of engines and there was a lot of crap under my intake. I changed the knock sensors and harness and rtv'd around them. I've cleared the codes, but they come back almost immediately. I don't have a check engine light, they are stored codes. I've had the 2 codes for over a week now.
Would it matter if the knock sensor harness is installed the wrong way? I'm 90% sure I installed it properly, since it was the only way the cable would reach, but if it makes a difference I could try switching the wires.
My truck idles fine and I have good vacuum, but it seems to be missing some power. Only upgrades are CAI and headers. I can hear some hissing and slight tapping, but the truck has 200k on it and I'm pretty sure that is the intake and rusty muffler.
Thanks for any help in advance.
Edit: I'm halfway through 40 gallons of 93 octane, so I don't think it's a problem with low quality fuel.
I used 1aauto parts, don't seem to be bad quality. Yes, torque was 190 in/lbs.
If I can't find anything else out, I will get the ACDelco parts and genuine
GM harness. Hopefully I get some more advice, since I really don't
want to replace something that's working fine.
Anyone have any bad experiences with 1A Auto parts? They have a 60 day guarantee so I can send them back and spend $30 more on ACDelco if that is the problem, but would like to try other things before tearing into my intake again.
Last edited by Suburban2500; Mar 1, 2016 at 08:59 PM. Reason: Bad cell phone typing.
1A Auto is giving me a refund without having to return the parts, so I will order the ACDelco knock sensors and better harness as soon as that is processed.
Although I'm fairly sure this will fix my problem, if it doesn't, who could I contact about getting a tune to turn the codes off and also, if possible, delete EGR? (Found a lot of crap in intake from it)
Edit: Blackbear won't delete EGR unfortunately.
-And, it seems to be missing power? (as if the knock sensors were disabled/ causing limp home timing)
Lets see. If the knock sensors were good to begin with, it explains why you are still getting the same codes after changing them. Following this logic, it leaves the harness, and the ECU. I would change/fix/wire/inspect the harness first, try wiring it directly to the computer for example ( go around all the OEM wiring, just look at the FSM schematic and find the knock sensor wire(s) should be very few of them, tap into them and run the wires directly to the sensors temporarily for diagnistics). It sounds like the ECU just isn't "seeing" them due to the harness issue.
I was only getting one low voltage code for the rear knock sensor, which I think was caused by the corrosion on it. In my (albeit somewhat limited) efi experience, one bad knock sensor is usually a faulty one, two bad ones are another engine problem. So I'm assuming the original harness, wiring, ecu was alright to begin with. The power was the same before I replaced, but it hasn't always been like this.
The new harness didn't appear to be broken, but it wasn't insulated well and was shorter than the factory part. It's annoying how hard to get to the knock sensors are, makes it really difficult to diagnose since there's no way to run the engine and have access to them.
I'm hoping that the cheaper sensors I bought were not quite right or broken in shipping, or the harness is wired incorrectly, but we'll see when the new knock sensors arrive. Seems like a lot of people have similar problems with any parts other than ACDelco. Probably should have sprung for the ACDelco parts to begin with, but 1Aauto didn't seem bad at the time. Figured it was better than eBay.
I think part of my problem was there was a lot of dirt in the rear knock sensor hole that I didn't catch last time. I have no idea how so much have gotten in, since it was all below where the sensor usually sits. My truck is fairly high up so I had to climb into the engine bay to even see it. Probably scooped out about a tablespoon of dirt, then hit it with degreaser and air until it was completely clean.
Dorman harness was identical to 1A's part other than packaging, which I don't really like due to lackluster shielding on the wires, hopefully it holds up though. I think my problem with the harness reaching was due to it getting stuck somewhere on the intake.
Thanks to everybody who helped.
'Squish' isn't really the term GM use's. It's more of a 'crush'.
Hope it works out OK.
My new bolts are expected in the mail soon today, and maybe I can get the Knock Sensors swapped out tomorrow or Wednesday.
-Kyle
They look just like the ones in this kit:
http://bavshasgay.blogspot.com/2013/...pair-kit.html#
I hope that's not correct...My repair is scheduled for tomorrow...
-KP
-KP
