running AFR to HP tuners without EIO, using AC PID
hey guys just read about putting 0-5v output for wb into hptuners with the AC pressure sensor. couple of questions for the guys doing this, do i need to completely cut this wire so only the 0-5v wire is going to it or can i just splice into it? secondly will this make it so my AC will not work?
Also, I'm using a dyno jet WB 2, hoping it will work but don't know how to know if the wideband range is 10-18 (not sure if that is just standard or if it is custom) and can't seem to find any info about the wb range on dynojets site.
On the HP Tuners Bulletin board, under Scanner, there is a nice writeup on how to do this and set up your scanner. There are several standard choices for widebands. I don't know if dynojet is one of them. You might have to do a custom.
