Wideband
Old Mar 18, 2016 | 05:11 PM
dr.mike's Avatar
For the AEM 30-0300, the gauge and controller are 1 piece. i.e. not a seperate controller/gauge like PLX, et al. So, all of the outputs are available.
EFILive SHOULD be able to pick up the OBD2 simulation data from the CAN bus on the modified units. It's just the normal PID 0x24 format. If you wanted to go that way.
The manual is here : http://aemelectronics.com/files/inst...or%20Gauge.pdf
The OBD2 simulation mode stuff is not covered there, as it is a special re-flash mod that I am doing.
Old Mar 18, 2016 | 05:22 PM
joecar's Avatar
Ok, it is an intgrated wideband controller/gauge... and the user manual indicates it writes the AFR on the serial comms port... so EFILive FlashScan V2 is able to read it...
you need a serial null-modem adapter (gender bender) to join the AEM serial cable to the EFILive V2 cable... and need to configure V2 serial com port to "wideband" and type to "AEM"...
then connect to powered up OBD-II port on vehicle, and V2 LCD can display wideband AFR and Lambda, and you can log those as external pids (pids are named EXT.WO2xxx).
Old Mar 18, 2016 | 06:32 PM
tadams72's Avatar
See, I told you joecar is a guru.
Old Mar 18, 2016 | 06:50 PM
dr.mike's Avatar
What would it take for EFILive to read the lambda information from the OBDII/CAN interface ? It just shows up as the standard PID.24 , using a splitter on the OBDII cable.
The CAN/OBD2 data can be scanned at up to 500Hz. The default for the serial data is only 10Hz. This is significant because the gauge has a t63 response time of around 10ms. ( 100Hz )
Old Mar 18, 2016 | 07:40 PM
joecar's Avatar
What is reading the serial comms...?
Does it have a serial comms repeater output...?
Old Mar 18, 2016 | 07:53 PM
dr.mike's Avatar
The serial com on the gauge is just an open output. Nothing is reading it, unless you connect something to it. So, there is no need for a repeater.
The display function does not use any of the outputs, for itself. It is connected, internally.
The gauge has 3 outputs.
1. The CAN bus lines
2. The 0-5v analog output
3. the serial output line
All three are available for use.
The mod that I did converts the CAN output to an ECU simulator to serve PIDs 24-2B for lambda data.
Old Mar 18, 2016 | 08:00 PM
joecar's Avatar
EFILive reads the serial output.
Old Mar 18, 2016 | 08:07 PM
dr.mike's Avatar
Ok.
My question was. Can EFILive read the lambda data from the gauge's OBDII/CAN interface ?
It works with HPTuners. i.e. When the gauge's CAN wires are connected to the CAN wires of the vehicles OBDII connector, HPTuners can read the lambda data directly, via PID 24, etc.
Old Mar 18, 2016 | 11:24 PM
tadams72's Avatar
Originally Posted by dr.mike
Ok.
If the gauge has a serial out you can get the cable joecar mentioned above, make adjustments in the EFI live software for an AEM input, and plug the cable in the rj11 port on the FSV2. It will read and data log lambda in BBX or as throughput to the laptop.
Old Mar 19, 2016 | 01:56 PM
joecar's Avatar
Ok.
I don't think it can read it from the CAN bus.
But it will read it directly from the serial comm output (with a null modem serial cable).
Old Mar 19, 2016 | 05:00 PM
joecar's Avatar
Ok.
Do you have have an EFILive FSV2 (I vaguely remember seeing you on the EFILive forum)...
do you have the serial comms cable that came with your FSV2...?
do you have the serial comm cable that came with your AEM...?
all you need is a $2 null modem adapter, see orange gender-bender looking device in this pic:
Old Mar 23, 2016 | 07:53 AM
  #32
RBCUDA's Avatar
Wow, this is over my head. I only have the V1, so I am hoping to use the analog outputs at this time. Pretty new to tuning, so not sure I want to pay to upgrade to the V2. If I can't figure the tuning thing out I'll just take it and get it tuned, but I really would like to figure this stuff out.
Old Mar 23, 2016 | 10:11 AM
  #33
joecar's Avatar
Default Wideband
FSV1 does not have serial comms...
do you will have to use analog.
( fixed spelling corrector typos )
Old Mar 25, 2016 | 07:44 AM
  #34
RBCUDA's Avatar
I knew it didn't. Not sure if I would upgrade to the V2 or just get HP Tuners if I decide to do something. I plan to try what I have for now.
Old May 7, 2016 | 09:08 PM
  #35
RBCUDA's Avatar
Hey dr.mike, are you still reflashing the aem 30-0300's?
Old May 7, 2016 | 09:38 PM
  #36
dr.mike's Avatar
Technically, the beta is complete. But, I guess I can flash a few more units here, until they are available pre-flashed.
Old May 8, 2016 | 01:29 AM
  #37
kingtal0n's Avatar
The AEM units have a linear 0-5v analog output iirc
It was the LC-1 innovative that used the serial. I dont remember any $150 AEM gauge every coming with a serial adapter, or any 9pin DB connector.
Old May 8, 2016 | 01:48 AM
  #38
joecar's Avatar
Default Wideband
Some AEM's have serial comms output, for example the AEM 30-4100.
Old May 8, 2016 | 03:34 AM
  #39
dr.mike's Avatar
They generally came with a bare wire for serial output. You would need to solder on a DB-9 connector.
Old May 8, 2016 | 02:01 PM
  #40
joecar's Avatar
Or you can fabricate a cable out of it (null modem style, Rx/Tx crossed, for connecting to EFILive FLashScan V2).
